• 0
Running collectors in Docker
Michael Baker
 Share
Question
Anyone else noticed this before? I have a case open but thought would try here... Some of our collectors not all when we upgraded them looks like the installer is templated and bombing out post install error
usr/local/logicmonitor/agent/bin/logicmonitor-agent: line 54: syntax error near unexpected token <'
/usr/local/logicmonitor/agent/bin/logicmonitor-agent: line 54: $SETNETCAP <JAVACMD> <SBAGENTROOT>/lib/sblinuxproxy 1>/dev/null'
I i grab that off another container (running) and copy it across it comes up fine happy to provide what log files is needed
Link to comment
5 answers to this question
  • 0
  • Administrators
11 hours ago, Michael Baker said:
Container on Centos8
Wait, I may be misunderstanding, but: you've built your own container for this? Why not use our image?
I've run Collectors in my lab almost exclusively in containers and i run into problems with the EA version sometimes. But our image is what is used to monitor the insides of K8s, so while the EA may have issues, the GA version is usually rock solid.
Link to comment
  • 0
We forked it due to some issues with ancient SDK's and many small bugs + needed to add some other dep's (wmic) in the run time and we got persistent mounts for things like netflow (If you crate /usr/local/logicmonitor/bin/netflow and persitent mount it the script says it already installed and refuses which we have a patch for) which it does not support..
Then there is this:
- Proxy support broken in offical one it does not honour the proxy settting's passed to the container ONLY for the initial python pull but not the install it self
- Netflow ports broken in official one will try bring container up on 2055 we have stuff bound to 2055 that samplicates
- Nbar reverts back to disabled
- Syslog ports broken same like netflow
- Some odd cert issues with the official one due to DNS caching and IP's changing
Message me if you want to see what we have done?
Link to comment
  • 0
To explain what it looks like in a bit more detail we have a number of boxes running collectors in docker on the same vlan.. They all run keepalived and samplicator, samplicator is bound to 514 and 2055 on each host which then forwards back to the host IP on 1514 and 2056 which i the ports we customised the agent to use. If we take ear down a collector it will find the existing one in portal download it with default config of 2055/514 and obv breaks
Link to comment
  • 0
  • Administrators
Yeah, i've run into this with our fork of the OTel Collector, the config gets overwritten when the installer runs. If a config is provided through a volume mount, i think it errors out. Definitely worth making it an option to pop in your own config files.
Link to comment
Answer this question...
 Share
