• 0
joshlowit1
SQL showing No Data
Question
Hi Team,
I have a couple of collectors that are showing No Data for SQL Server. Now the SQL servers do not get used a lot as they are in a test environment, would that cause the collector to say "No Data" on all metrics? I have checked and I do not see "No Data" on other item such as CPU or memory which leads me to believe it is not a WMI issue as I have found in the past. Any ideas?
Share this post
4 answers to this question
  • 0
So WinSQLServer- DataSource doesn't use WMI but uses PERFMON. Looking at the bottom of the screenshots you can see it got "NaN" for several items. I can't speak for SQL directly but many times when I see perfmon issues in windows, it usually due to the counters missing on the system itself and that you need to repair them. I would google something like "perfmon mssql counters missing" and try reviewing some of the items listed there.
Share this post
  • 0
To provide some more generic information when you see "No Data" on the resource page... The first thing I suggest you do is go to the Raw tab and use Poll Now. This actually can provide a lot of useful troubleshooting information. It will show what it attempted and the output or results. If you post a screenshot of it, we might be able to help out. You might want to block/blur out any sensitive information though.
Share this post
  • 0
I am attaching a couple of screenshots. Just states "No result returned for referred counter." All other counters seem to be working ok.
Share this post
Answer this question...
