• 0
FTP check with Groovy script
Question
I am trying to use groovy to verify the connectivity of an FTP server following the FAQ (http://help.logicmonitor.com/using/da...)
Here is the exact script used:
import com.santaba.agent.groovyapi.expect.Expect
cli = Expect.open(\'\'x.x.x.x\'\', 21, 5)
cli.expect(\'\'220 \'\')
cli.send( \'\'user anonymous
cli.expect(\'\'331 \'\')
cli.send(\'\'pass meme
cli.expect( \'\'230 \'\')
cli.send( \'\'quit
Unfortunately, the groovy debugger wither comes back with a timeout, or the following:
>> !groovy
End of stream reached, no match found
My FTP server, in turn, see the connection coming from the agent, but never receives the \'\'USER anonymous\'\' command.
Any Help welcome
3 answers to this question
  • 0
  • LogicMonitor Staff
In the coming release, in a week or two, there will be direct access to all properties of a host.n
nRight now you can use HOSTNAME and WILDVALUE (quoted) in scripts.n
nYou can also pass in any property as a parameter to your groovy script, and then access positionally:n
ne.g.n
nhost = this.args[0]n
nso youd use HOSTNAME as the parameters to your script in the datasource screen.n
nThere is currently a risk that WILDVALUE, when substituted, could break the script syntax (if the WILDVALUE object contains a quote, say). That risk will go away in the coming release.
Answer this question...
