• 0
Antony Hawkins
Can I monitor two hosts with the same ip address?
Question
Is this possible? I want to monitor the routers of two networks. They both have (internal) IPs of 192.168.0.1, naturally enough. Each is monitored by a different agent and each is (would be) in a different group (as in, one exists in one group, monitored by one agent, while I am attempting to add the second to a second group, monitored by a second agent).
However, when attempting to add the second, I get:
\'\'Unable to load data from the server - Host already exists\'\'
Is this possible?
Many thanks
Share this post
1 answer to this question
  • 1
Yes it's possible, so long as each host is monitored by a different collector, and has a unique display name (to make clear what alerts, etc are referring to.)
Note that you cannot add duplicate IPs using the Add Host wizard - you have to use the Add Device Expert mode.
Share this post
Answer this question...
