• 0
Sign in to follow this
Ben Tucker
Passing arguments to Groovy Script
Question
Can I pass host properties from the portal into a groovy script?
for example, in the \'\'Access remote servers via SSH session\'\' documentation example, the example code starts:
Line 1. import com.santaba.collector.groovyapi.expect.Expect
Line 2. cli = Expect.open(\'\'192.168.211.129\'\', \'\'root\'\', \'\'xxxxxxx\'\')
I\'d like to set some host parameters like
myservice.user = user
myservice.pass = 12345
and access them with something like the following:
Line 2. cli = Expect.open( some_hostname_variable , some_properties_map[\'\'myservice.user\'\'], some_properties_map[\'\'myservice.pass\'\'])
does some syntax like that exist? if so, where can I read more about it?
Share this post
2 answers to this question
  • 0
Yes - see http://help.logicmonitor.com/using/datasource/creating-datasources/collectors/script-collector/groovy-support/rnSpecifically :rn
  • rn
  • Accessing all host properties - all properties of a host are accessible from groovy scripts via accessing the map hostProps.get(property). With other scripting languages, this requires passing in the properties as parameters. But in groovy, its as simple as accessing the hostname via: hostname = hostProps.get(system.hostname);rn
Share this post
  • 0
Ben, host properties are split into 2 groups: System properties, and custom properties.rnScreenshot: http://imageshack.us/f/545/sn8u.png/rnSystem properties can be referenced by hostProps.get(system.property) Where property is replaced by the specific property: location, ips, displayname, etc. i.e hostProps.get(system.ips)rn rnCustom properties are usually created with the property.name format. For example: snmp.community, wmi.user, etc; but you can specify the property name any way you like. When referencing the custom property just use the exact name of the property. i.e. hostProps.get(ssh.pass) assuming ssh.pass is specified as a custom property on the host.
Share this post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
