• 0
Kel
PagerDuty Integration? I'm stuck...
Question
Howdy,
I'm trying to setup the integration between LM and PD and I'm stuck at creating the user.
I'm going through this LM document: https://www.logicmonitor.com/support/alerts/integrations/pagerduty-integration/
And this PD document: https://www.pagerduty.com/docs/guides/logicmonitor-integration-guide/
I have everything setup but I'm not sure where in LM I go to add this integration as a contact method for a user in an Escalation chain to actually put it into use.  Can anyone help me figure out where to go next?
Share this post
2 answers to this question
  • 0
I don't use PagerDuty itself so I'm making some guesses, but with Integrations in general you can use any active normal user in the escalation chain. I have a special "integration send" user that has a role with virtually no access and use that user just for our integrations.
Share this post
  • 0
When you create the Escalation Chain, you need to create Stages. In the escalation chain choose the "+" next to Stages to create a new stage. This will popup a "Add new recipients" window. Click on the "+" which asks for a user, pick/type-in a user as mentioned above. Once you pick a user, it will offer a "Contact Method" box to the right where you can pick your PD integration. This will only show up if you pick a normal user, does not work for groups nor api-only users. Click on the white save button then the blue save button.
Share this post
Answer this question...
