• 0
Internal web check with request/response Groovy script to check external FTP site
Roland Banks
 Share
Question
  • LogicMonitor Staff
Is it possible to check an FTP site using an internal web check, and using Groovy script in the request / response?
This URL (https://www.logicmonitor.com/support/services/adding-managing-services/executing-internal-web-checks-via-groovy-scripts/) seems to indicate the commands that can be used, as if it's limited in some way.
I can't think of another way to check the alive-ness of an FTP site somewhere on the web via LogicMonitor, if the device isn't in LogicMonitor itself.
Any ideas?
Roland.
Link to comment
1 answer to this question
  • 0
Hey @Roland Banks,
That should be possible - the commands listed there are mostly Groovy methods that have been added on by LogicMonitor, which doesn't necessarily mean we're locking down Groovy capabilities in other ways. If you happen to own the LM Config add-on, there's an example of a Groovy script logging in via FTP and pulling the contents of a file:
import org.apache.commons.net.ftp.FTPClient
import org.apache.commons.net.ftp.FTPReply
def host = hostProps.get("system.hostname");
def port = hostProps.get("ftp.port") ?: '21';
def user = hostProps.get("ftp.user");
def pass = hostProps.get("ftp.pass");
def client = new FTPClient()
client.connect(host, port.toInteger())
// After connection attempt, you should check the reply code to verify
// success.
def reply = client.getReplyCode();
// Did we get a positive completion reply?
if (!FTPReply.isPositiveCompletion(reply))
    // no, disconnect
    client.disconnect();
    println "FTP server refused connection.";
    return 1;
// Connection looks good, login
client.login(user, pass)
// Create a BAOS to store the file contents
ByteArrayOutputStream baos = new ByteArrayOutputStream()
// Retreive the file
client.retrieveFile("##WILDVALUE##", baos)
// Log out and disconnection from the server
client.logout()
client.disconnect()
// Print the contents of the file from the BAOS.
println baos
return 0;
Hope that helps!
Cheers,
Kerry
Link to comment
Answer this question...
 Share
