mkerfoot 14 Report post Posted January 23, 2018 WALDXL - Download Speed This datasource will run a PowerShell script that downloads a 10MB file and then figures out the speed in Mbps that it was downloaded. CAUTION: This datasource will download a 10Mb file for every Windows machine specified in the applies to field(default is not applied),every poll(deafult is 20 minutes), depending on your environment this could raise the price for your monthly ISP bill. Specifically if your ISP speeds ramp up when needed. I would recommend applying this to: hasCategory("speed") and isWindows() The of course you just need to add the system.property of speed to any Windows machine you want to monitor Download Speed on. 2 Quote Share this post Link to post Share on other sites
Nathan Sanders 0 Report post Posted July 13, 2018 Looks like LM placed under Security Review Quote Share this post Link to post Share on other sites
mkerfoot 14 Report post Posted July 13, 2018 (edited) @Andrey Kitsen Any chance you could expedite the security review process on this one? Edited July 13, 2018 by mkerfoot Quote Share this post Link to post Share on other sites
Michael Rodrigues 100 Report post Posted July 14, 2018 @mkerfoot, @Nathan Sanders this module is through review, so you should be able to import it now. Thanks for contributing! Quote Share this post Link to post Share on other sites
Nathan Sanders 0 Report post Posted July 28, 2018 Deployed to our collectors and after setting wmi.user/pass for the script to use getting this error back. Thoughts? NaN Attribute not valid or not found in output - (method=namevalue, param=Speed) Quote Share this post Link to post Share on other sites
