Joe Tran
Built in aggregation options for Get Data APIs
I'm on hour 17 of a run of a script that pulls down Service responseTime data for about 345 services so I can come up of an average across all of those services from the last quarter.
I would love, LOVE a built-in option or parameter to aggregate this data in the API call. :S
Share this post
Hi Joe,
Thanks for the request - we'll look into it!  Are you making this type of calculation for device datapoints as well? (e.g. averaging a key performance metric across multiple servers all supporting the same service).  And is this something you'd want to visualize in a LogicMonitor dashboard widget / report, or that you're pulling into another tool?  Just trying to get a bit more context re the use case :)
Sarah
Share this post
Hi Sarah,
As far as I know, I should be able to visualize aggregate device data using a Custom Graph widget. This is something that is lacking for Services though.
My coworkers in the business analysts teams do import LogicMonitor data into Tableau.
Joe
Share this post
Reply to this topic...
