Cisco Info PropertySources
Tom Lasswell
 Share
This one goes into some additional detail but hasn't been completely cleaned up for debugging purposes.
The ones that have switch stacks pull all the stack serials and model numbers. Work in progress was the versioning. We have about 1500+ network devices across many many different models and versions so this has taken a little bit of work to get to work across all.
MWXMXZ - Cisco-IOS
FKA79M - Cisco IOS XE
9LF63N - NXOS
G366DD - Cisco ASA
Edited by Tom Lasswell
  • Upvote 2
Link to comment
  • 1 month later...
  • LogicMonitor Staff
MWXMXZ - Cisco-IOS
9LF63N - NXOS
G366DD - Cisco ASA
@Tom Lasswell I've split your contribution into this separate topic.
Link to comment
  • 2 months later...
  • 2 months later...
I haven't kept up on this thread for sure. :) I do have some modifications to these but mostly there's some cleanup i need to do on some dupe properties that are created for testing purposes (to make sure numbers matched up). I'll see if i can get updated ones finished up this week as I also need to get this done for some of our CMDB efforts we're working on.
Link to comment
@Tom Lasswell I noticed it wasn't pulling anything for switch stacks so I modified it a bit to get around that.  Of course, this will only show the data for the stack master, but it can definitely still be useful.  I know there's a separate datasource that pulls the data for all the units in each stack, but oh well - better to have it twice than not at all!
// set hostname variable.
def hostname = hostProps.get("system.hostname")
// Wrap code in try/catch in case execution experiences an error.
try
    // OID which contains the serial number of Cisco devices.
    def entPhysicalSerialNum = "1.3.6.1.2.1.47.1.1.1.1.11.1"
    // Initiate SNMP GET command.
    def output = Snmp.get(hostname, entPhysicalSerialNum);
  // Null response could mean switch stack.
    if (output == null)
        try
            def entPhysicalSerialNum2 = "1.3.6.1.2.1.47.1.1.1.1.11.1001"
            def output2 = Snmp.get(hostname, entPhysicalSerialNum)
            println "auto.Cisco_Serial_Number=" + output2
        catch (Exception e)
            // print out the exception.
            println e;
            return 1;
    // Print out the serial number.
// Catch the exception.
catch (Exception e)
    println e;
    return 1;
// exit code 0
return 0;
Link to comment
  • 3 months later...
Hi All, I am new to the forum and LM and require some guidance on how to extract the multiple serials for a switch stack as per this thread. The screenshot above is exactly what I am looking for. Do you guys freely share the Groovy script code on this forum or was it posted on a different thread?
Regards,
Kris
Link to comment
Regards,
Kris
Hey @Kris welcome to the forum.
You will find Locator ID's being shared which can be used inside the LogicMonitor portal to find and import the modules. If you need any help figuring out how that all works, you can always reach out to the LM Support team and they can guide you if necessary.
Here's a page that can help get you started : https://www.logicmonitor.com/support/settings/logicmodules/lm-exchange/
Edited by Andrey Kitsen
- added get started link
Link to comment
  • 8 months later...
On 30/01/2018 at 6:21 PM, Tom Lasswell said:
I did something very similar @Brandon, trying to get the detail around each stack to be utilized in our CMBD. Need to get this out at some point :) I used two methods to display it, one is for each for the number of switches individually and then one comma seperated with the switch deliminator at the beginning.
Hi Tom,
I am new to LM and would like to do exactly that. Did you share a locator code for this or are you happy to share the code?
Link to comment
  • 1 month later...
On 1/14/2019 at 6:11 AM, lukem@itgl.com said:
Hi Tom,
Hi there, I've moved on to another company and don't have access to this anymore, but it was some additional information in the groovy script that just each time it iterated through the serial numbers it added additional properties. A crash course in groovy is going to be very helpful for you being new to LM!
Link to comment
  • 1 year later...
We have an issue with our Cisco ASR's.  The entPhysicalEntry returns the main chassis SN along with all of the other installed modules SN's.  The problem is that it's setting the SN of a module other than the main chassis.  This then syncs back to our CMDB with the wrong SN.
Have any of you guys encountered this?  The excerpt below is from a custom prop source we have but is also included in the main Device_BasicInfo prop source.
    // entPhysicalEntry
        def seenOidTypes = [];
        def entWalk = Snmp.walk(hostname, ".1.3.6.1.2.1.47.1.1.1.1");
        entWalk.split('\n').sort().each{
            line ->
            def ipNodeMatcher = line =~ /^\.1\.3\.6\.1\.2\.1\.47\.1\.1\.1\.1\.(?<oidType>\d+)\.(?<entPhysicalEntry>[\d\.]+) = (?<value>.+)$/;
            if(!ipNodeMatcher.matches())
                return;
            // We have a match
            def oidType = ipNodeMatcher.group('oidType');
            def entPhysicalEntry = ipNodeMatcher.group('entPhysicalEntry');
            def value = ipNodeMatcher.group('value');
            // Only do this once per oidType
            if(seenOidTypes.contains(oidType))
                // Already seen
                return;
            // New one - add to seenOidTypes
            seenOidTypes.push(oidType);
            switch(oidType)
                case "1":
                    println "entPhysicalIndex=${value}";
                    break;
                case "2":
                    println "entPhysicalDescr=${value}";
                    break;
                case "3":
                    println "entPhysicalVendorType=${value}";
                    break;
                case "4":
                    println "entPhysicalContainedIn=${value}";
                    break;
                case "5":
                    println "entPhysicalClass=${value}";
                    break;
                case "6":
                    println "entPhysicalParentRelPos=${value}";
                    break;
                case "7":
                    println "entPhysicalName=${value}";
                    break;
                case "8":
                    println "entPhysicalHardwareRev=${value}";
                    break;
                case "9":
                    println "entPhysicalFirmwareRev=${value}";
                    break;
                case "10":
                    println "entPhysicalSoftwareRev=${value}";
                    break;
                case "11":
                    println "cmdb.serialnumber=${value}";
                    break;
                case "12":
                    println "entPhysicalMfgName=${value}";
                    if(manufacturer == "")
                        manufacturer = value;
                    break;
                case "13":
                    //println "entPhysicalModelName=${value}";
                    println "cmdb.model=${value}";
                    break;
                case "14":
                    println "entPhysicalAlias=${value}";
                    break;
                case "15":
                    println "entPhysicalAssetID=${value}";
                    break;
                case "16":
                    println "entPhysicalIsFRU=${value}";
                    break;
                case "17":
                    println "entPhysicalMfgDate=${value}";
                    break;
                case "18":
                    println "entPhysicalUris=${value}";
                    break;
                default:
                    // Ignore
                    break;
Link to comment
Reply to this topic...
 Share
