• 0
LM-User99
Cisco WLC - Users per AP
Question
Hello, I'm a new user.
Started monitoring a Cisco WLC5508 and it did a good job of picking up the APs.
We need to see how many users are on each AP to verify they are not oversubscribed.  LM has a "Top 10" graph that shows how many users per AP radio, and there are 2 radios per AP at the site.  Is there a way to see this for ALL APs, and is there a way to see it by AP and not by radio?
Any feedback would be appreciated.
Share this post
1 answer to this question
  • 0
Hi there,
One way to change the way you can visualize this would be to use custom graph widgets on a dashboard. You should be able to combine or divide the AP Radio instances among graph widgets on a dashboard to meet the needs you mentioned.
Good luck,
nin
Share this post
Answer this question...
