Sign in to follow this
DBA_Troy
Failover Collector confusion
LM Team,
When you are on your primary collector and choose a failover collector and are deciding to check that box "Automatically failback when THIS collector becomes available again". The way that it is worded, THIS collector could mean the current collector you are configuring. Then again, the checkbox is underneath the failover collector you just selected and it is indented, so it's easy to convince yourself that it could be referring to the failover collector.
I think it would be worth re-wording or at least offering a hover-hint (?) box to clarify that the failback will be occurring on the collector you are currently configuring. Looking back, I had checked this box differently depending on how I felt that day and which made most sense to me at the time. Some clairification would be good.
  • Upvote 1
Share this post
Reply to this topic...
