More AWS-centric options for Netscan via AWS (EC2) Method
- Token to name a device based on AWS tag
- The ability to exclude devices based on region
- All AWS tags should be imported/populated/inherited
- Netscan should populate the system.aws.resourceid property instead of system.ec2.resourceid. The former is actually used by the default AWS_EC2 datasource. Probably moot if my third bullet is done.
Edited by Joe Tran
I guess I need to read the support documentation better. Looks like the last two items are moot points if I configured my netscan correctly.
However I still stand by the first two:
- Token to name a device based on AWS tag... most convenient would be the Name tag.
Reply to this topic...
